Stair Material and Visibility Corrections
On floor pattern plans, it's very difficult to represent the finish for stairs. You can assign a material to the treads in their type properties but I haven't found a way to assign a material to the landing. You could override the graphics in your view but the landing patterns aren't available. If you override the pattern for stairs it also shows through the railings like in the image below. The only viable workaround I've found currently is to use a filled region for the landings which is obviously undesirable.
It would be great if you could assign materials to stair landings or if stair subcategories were available for graphic overrides.
It would also be great if you were able to split the face of the tread to show tractions strips or contrasting nosing.
And please, oh please, add <Below> to the subcategories.
1 Comment
vanengelenhovenm
It would be nice if you were able to align the fill pattern of each individual tread in plan view and not have the fill patern just run over the whole stair like the stair tread lines mean nothing.
