Split Views on Sheets and Move Vertically and Horizontally
I love that Revit allows you to split views on sheets so that you can show a break in them if they are too big. But sometimes they are still way too big to go side by side on a sheet. It would be nice if you could split a view, like an elevation or section, and move one below the other instead of only next to it.
1 Comment
Mark_Engwirda
@Anonymous, for me this is a regular occurrence.
Currently, the only way to achieve the desired outcome is to crop the original view and create a duplicate view for the second view that won't fit on the sheet.
Currently, we can only split views in either a horizontal or vertical direction
The proposed idea by @Anonymous allows the split view to be moved horizontally or vertically on the sheet in the same way that schedules can be split.
Example of a split schedule where the split view can be offset in both the horizontal and vertical planes
This would be a great time-saving idea if it was implemented.
