When Adding/Removing segments from curtain grid lines, you have to first select the grid line, select the "Add/Remove Segments" tool and then select each grid. When editing dozens of grid lines, this is quite time-consuming.
Much faster would be, if you could select the curtain wall, then select the "Add/Remove Segments" tool, all the grid lines become visible and you could just click on each segment you want to add/remove.
Changing this functionality would save us a lot of clicks and time.
