Shared Parameter Selection UI Remember Group
It would be nice if the UI for selecting shared parameters opened back up with the group previously opened when last selecting a shared parameter. Currently it always defaults to the group at the top of the list (annotation parameters).
I am in the process of updating several hundred door families with some new shared parameters and and I need to click the drop down every time and select the "doors" group to get to the parameter I want to select.
It would save me a lot of time and clicks if this was implemented.
It could be set per session/Revit instance and then revert to the default when Revit is reopened.
2 Comments
MiWolff
As a work around, I tend to rename the group I am currently busy with to "!Group I am currently dealing with". That way it comes first in the list and will be presented when returning to the dialogue. May get a little crowded if you forget to rerename once done.
Mike.FORM
@MiWolff that is definitely a good tip. I will remember that going forward.
