Remove the 'Exclude Options' tick box and create a selection toggle for Design Options.
Give us the control to be able to select design option elements all the time. The "Exclude options" tick box is functionally flawed as it resets when you hit escape. It is not an intuitive tool.
Replace it with a toggle for Design Options for consistent behaviour of element selection.
A few releases ago, Autodesk gave us a series of selection toggles for Links, Underlays, Pinned Elements, Select Elements by Face and Dragging Elements. The ground work has already been created, let's add to this set of toggles for more consistent and predictable behaviour.
(The 'Pick to Edit' tool could still override as it currently does)
Thanks for Voting.
