When using the UI upon selecting an Element which has a circuit the Ribbon Tab "Electrical Circuits" appear, in this Tab one can click the button "Select Panel" or you can use the drop-down list which shows all the compatible panels.
I would want a similar function in the API to get a list off all the compatible panels for a certain circuit, this currently doesn't seem possible.
The reason why this is needed is because the drop-down shown in the Ribbon only shows the Panel Names and sometimes more information is needed, because a panel name isn't always unique.
In the past I've asked this on the API forum (https://forums.autodesk.com/t5/revit-api-forum/select-panel-for-circuit/td-p/6983630), but nobody came up with an answer how this could be done.
Is there a way I can get all the compatible panels for a circuit through the API?
Kind Regards
