The intersection or joint between a vertical mullion and a horizontal mullion in an elevation of a curtain wall is currently represented by a line at the end of the member which is not continuous at that joint. Furthermore, Revit allows users to dictate which mullion (whether horizontal or vertical) is continuous at the joint with a graphic toggle. Would it be possible to be able to toggle that graphic so that no joint line shows up at that joint (as a third option)?
