Show only
Search instead for
Model Patterns can be rotated, why not Drafting? We've got a lot of drafted details that would look a lot nicer if the patterns would line up with the elements.
Any updates on being able to rotate a drafting pattern? This was marked future consideration in 2018. This is a huge design flaw in Revit's drafting capabilities.
@kimberly.fuhrmanIs there any progress on this? This issue is currently driving me crazy on some details I am working on - I would like to be able to rotate a piece of plywood so that my detail is legible.
Very frustrating that rotating a hatch pattern has been put in the too hard basket!! It's 2022 and we still can't rotate a simple pattern... PLEASE PLEASE PLEASE can you get the basics such as this working properly before offering any new features in Revit. It is 15 years after starting to use Revit in our office, and finding and implementing workarounds to get our drawings looking legible still consumes an extraordinary amount of time and profit.
So, its been 6 years now since this very reasonable request and no progress. In 2023, we now have an updated colorization for dynamo (completely unnecessary) but can't align drafting hatch patterns with their detail elements. We don't even have a rotation parameter for hatch patterns, so if we need to rotate the hatch pattern, we need a new name and new hatch pattern code, bloating the pat files with unnecessary code. Adding the type selection for nested fill region patterns was a good step forward but drafting pattern alignment is still a prerequisite for detailing.
Autodesk, change your priorities to implement this, this is actually needed to make decent looking construction documents, unlike everything in Revit under Massing tab.
At this moment its not possible to align drafting hatches to the element although this option is available within filled region, its actually not working.
Maybe fix the issue with similar patterns placed in plan view with automatic rotation : for example: I place the patter ANSI133 oriented to 90 degrees and in plan view is placed automatically at 45 degrees and is the same with another plant patter ANSI133-45 degrees orientation and in plan view is placed automatically 45 degrees an the patterns in plan view look like the same pattern. Either fix this behavior or avoid to have similar patterns that appear the same in plan view
Ten years on and still nothing on this? It's frustrating that even Autodesk's own default Plywood detail component from the cloud library doesn't function properly. Having to build out multiple custom hatch patterns to work around this, when it should be handled out of the box, is a real letdown.
