I've been using Revit for over a year (I'm user-certified), and I've done tons of research into specific step-by-step instructions regarding certain processes. Sadly, I've found many frustrated Revit users that are unable to use basic functions that programs like AutoCAD have been utilizing for many years. I know that both programs are different, and their purposes can vary, but many people who have been using AutoCAD for 10+ years are unwilling to transition to Revit for seemingly obvious and rational reasons. I know that Revit can deliver more results than AutoCAD, and that BIM is the new standard, but I still feel more comfortable using AutoCAD merely because of its variety of functions. Revit seems to be lacking these essential functions.
Here's a few key comparisons and issues that have impacted my efficiency and ability to deliver results as quickly as I should:
1. The "Midway between two points" command: I used this a ton when I used AutoCAD Architecture to compete in a drafting conference. It saved me time and guaranteed accurate results. Revit doesn't have this function, and my research has led me to believe that I would have to run a complex script or use a special component as work-around.
2. Subregions don't snap to each other: After creating a basic and flat topographical surface, I created subregions that represented grass, sand, and sidewalks. When I sketched these subregions and wanted them to touch other subregions, I was unable to snap to their edges. The only work-around that I found was to create the entire site plan in AutoCAD, import that CAD file into Revit, and use it as an overlay that I traced. Why do I have to use a second program's lines to trace over? Why can't I snap to the corners and edges of other subregions?
3. Walls drawn at irregular angles don't have snaps or dimensions: When I try to place a door or window into a wall that's not exactly horizontal or vertical, the linear dimension guide disappears and I'm unable to snap to any face on that wall. This is extremely frustrating: Placing a door on a wall in a specific location takes me seconds in AutoCAD Architecture, regardless of what angle the wall is oriented. In Revit, I have to create and switch to an elevation view and use reference plane lines or model lines as guides. This is extremely time-consuming and inefficient.
I hope that someone can assist me in overcoming these shortfalls. Perhaps I haven't turned on a setting that enables these obvious functions. Perhaps my research is incomplete and outdated. Nevertheless, if it's this difficult for me to do research and figure out how to perform basic functions in a BIM program, then the program needs to be updated and given an easy-to-access set of complex tools that every draftsman/designer/architect/engineer needs to complete accurate projects.
P.S.: If I posted this in the wrong place, that's because Revit isn't on the "Product Feedback" list: https://www.autodesk.com/company/contact-us/product-feedback. Please guide me to the proper "forum" if this is the wrong place to discuss my post.
