Revit Exporter to Json
Taking into account the increasing use of the Json format for the visualization of 3D models in the cloud, it would be great to have an exporter included in Revit.
7 Comments
I think this is relatively easy to implement via the Revit API. Also take a look on the already posted blogs of Jeremy Tammik on this: http://thebuildingcoder.typepad.com/.services/blog/6a00e553e16897883300e553fcc7418834/search?filter....
novesvalentin
harmenverbug,
As a matter of fact that is the way I do it, but it would be great to have this as an standard with revit and not like an addin, so people can get use to work with these type of formats that are being use more and more every year.
dgorsman
Add-ins are easier to "break out" for updating and debugging; for example it's easier to update an add-in for earlier releases.  When a feature is built-in or embedded into the core program, that means all sorts of version and update controls get involved to avoid conflicts with other work.  As well as getting bumped off the development schedule by other priorities.
Does the JSON Exporter transfer all the parameter data from the revit model?
Does the JSON exporter contain the parts parameter data? Or is graphical data only?
esk0r
I literally just searched online for "revit to json" and I find you here 🙂
You got my vote!
Saludos!
@esk0r long time no see! Trying to get Autodesk to add a Json export would be awesome.
