Hello dev team,
Revit Assistant introduces very promising possibilities through natural language interactions. However, an ambiguous, incomplete, or poorly written prompt could lead to unintended modifications to the BIM model.
To increase user confidence and make AI usage safer in complex BIM projects, it would be valuable to introduce a validation system before any modification is applied to the model.
Two Possible Approaches :
1. Optional “Safe Mode”
Add a setting in Revit Assistant allowing users to enable or disable a mode that prevents direct modifications to the model.
When this mode is enabled:
This would allow users to adapt the security level according to their workflow and project context.
Before any modification is applied to the model, automatically display a confirmation dialog showing:
The changes would only be executed after the user validates this confirmation window.
Regards
Olivier
