Apply transparency for filled region in the type properties
I know there work arounds like grouping a number of filled regions especially if the have solid coloring then applying transparency to the group. The issue you with this is you then have to do it every project.
By adding the transparency to the type properties you its automatically done and you only need to set it up once for template which you can use for new project
