Revit API - edit wall vertical profile
Hi!
I'd like to suggest adding in the Revit API the possibility to edit the vertical profile of walls.
Currently, it is only possible to build a wall from a vertical profile, but it is not possible to edit the vertical profile of an existing wall.
In the post below I give details of the problem:
https://forums.autodesk.com/t5/revit-api-forum/edit-wall-vertical-profile/m-p/9628836#M48373
Since Revit 2016, I have encountered this problem and when I approached it in Revit 2019, to my surprise, this limitation is still present in the API.
Regards!
Prof. Ari Monteiro
BIM Consultant at Dharma Sistemas
www.dharmasistemas.wix.com/home
4 Comments
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
We are pleased to say that this has been implemented in Revit 2022!
-The Factory
Tarek_K
Status changed to: Gathering Support
Tarek_K
