Revit ACC Desktop Connector Local-Server Accelerated Caching
We have many users that at co-located in our offices working on the same projects. These projects contain many gigabytes of linked files. When a user opens a model they have to cache the latest links from the cloud every day. This means that the same large files are being downloaded by 20+ people across the office most mornings. This puts an unnecessary strain on internet bandwidths, and slows down opening times within Revit.
My idea is this - for an office, a local server instance of the desktop connector caches the latest models. When Revit opens a model, it queries the cloud for the latest version of that file and any associated links,. It then checks a local server cache to see whether the files already exist, and transfers from this local repository instead to the users collaboration cache. This will take advantage of superior local network speeds. If the file isn't up to date, it downloads directly from the cloud instead.
The Local-Server instance of the Desktop Connector would cache any model that is queried by the Revit instances within office rather than caching all the data that exists on the project.
Anyone working remotely would continue to utilize the existing process of caching directly from the cloud.
2 Comments
Ric_Weber
If I'm understanding this idea correctly, this would allow all of the models, dwgs, and other files that are linked to ACC to reside on a local server and then just mapped to a local location?  Or in my mind, even better, no reason to even map the file to local unless specifically set up to.
kevin_fielding
Not quite.
The local server desktop connector would act as an accelerator. You would link to the cloud data inside Revit and the accelerator would provide the links instead of being serviced by the cloud server.
The benefit would be that the accelerator would be caching the data once rather than an entire team downloading it.
