Revision Sequence
Revision Sequence
It would be amazing if the sheet issue/revision dialogue permits to add a new revision wherever we want instead of adding a new one at the bottom and have to move it all the way up where it should be! then you may miss which one was issued and which on was not issued!
I face this problem when I work on large projects with 350+ revision sequences !
or  ie. planning and building regulation drawings were done in Autocad then tender and construction on Revit so every single drawing must be converted to Revit.
