Revision "Numbering" Field visible when placing revisions.
With the ability to customize revision numbering it would be useful if the "numbering" information was shown when selecting to place "revisions on sheet" as per the sheet properties, and when placing revision clouds. Alternately being able to edit the "sequence" as text would solve this issue.
We customize the number to go along with our filing sets, which we currently have 15 different filing sets.  Each require different revisions for filing and post approval amendments.  It was great that there is the ability to add customized numbering but I can never tell which one I need to put on the sheet without going into the Sheet Issues/Revisions settings first to look up which sequence I need on the sheet.
Revision settings look like this below.
Placing a revision cloud looks like this, I cannot see the "numbering" so in this example I need to look up which sequence has Filing for FN numbering set.  I need to go into the settings to find this info.
Same with the image below when I try to add "revisions on sheet" through the sheet properties. I cannot tell which "numbering" I am using I need to again look it up in settings.
