Reference plane cuts for concrete beams and walls
You can cut steel beams at angles with reference planes, it would be good if this could be done with concrete beams and walls too.
4 Comments
samuelsanf
I think is possible (with named reference planes) using Part (Divide Parts). But I didn't know if this split the analytical model.
Yes it is possible using parts however that process is rather long winded, if we can cut using reference plane it will take 2 clicks !
Is there any way to cut concrete columns I think divided part is not possible with concrete column
bradwitt
When you slope a steel beam you can use a reference plane, in an elevation view to square off the end of the beams. For some reason you cannot do the same thing with a concrete beam. Concrete can be formed in any shape so this should be able to be accomplished the same way as a steel beam. Please see the video attached for the example.
Tags (4)
