Redlines to Revit
Allow Revit MCP to read redlined PDFs or Bluebeam markups and turn them into proposed Revit changes.
A typical workflow could be:
1. Export a drawing set from Revit.
2. Mark it up in Bluebeam.
3. Give the marked-up PDF to the MCP.
4. Have it identify the affected sheets, views, and model elements.
5. Review a list of proposed changes.
6. Approve the changes individually or in batches.
7. Have the MCP make the revisions and provide a summary of what changed.
This could handle common redlines such as:
* Move a wall
* Change a door size
* Rename a room
* Add or revise dimensions
* Delete or revise notes
* Update detail references
* Add missing tags
* Apply the same change to similar conditions
The important part is that the MCP should distinguish between straightforward drafting changes and items that require architectural judgment.
It would also be useful if each markup could be tracked as **Completed, Needs Clarification, or Not Implemented**, creating a direct round-trip workflow between Revit and Bluebeam.
Ideally:
**Revit → PDF markup → MCP review → approved revisions → Revit**
