Annonces
annuler
Affichage des résultats de
Afficher  uniquement  | Rechercher plutôt
Vouliez-vous dire :
"Varies" for Multiple Parameters instead of a blank value
When you select multiple instances of an element and if they have different parameters it would display 'Varies' in the parameters value rather than a blank white box that appears to be an empty value.  .
This would greatly help when you have items in a schedule that are not sorted with  'Itemize every Instance' checked
28 Commentaires
tamas.deri
It would be very important to have the ability to distinguish between empty values and multiple values in case of multiple selected elements or in grouped schedules, like how AutoCAD does. (I'm not an AutoCAD user, thats just an example, chill! :D) Also there could be a fastfilter option for multiple values, to filter down the selection to unique values. For numeric values a tooltip could show some basic information, like min, max, average, sum, etc.
BHamlet
tamas.deri
Right, sorry I was searching for "variable" instead of "varies" beforehand. Can be merged.
Thank you, @tamas.deri  and @BHamlet . I will merge these Ideas and the Kudos.
Statut modifié en : Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
Statut modifié en : Implemented
We are pleased to say that this has been implemented in Revit 2022!
-The Factory
Tarek_K
Statut modifié en : Gathering Support
Tarek_K
Vous n'avez pas trouvé ce que vous recherchiez ? Posez une question à la communauté ou partagez vos connaissances.
Proposer une idée
