Show only
Search instead for
Ability to set a default location for exporting PDFs in the settings -- Every time I restart the software the default goes back to my Documents folder.
I am using '22. There's a path for "user files" under file location settings, but this does not seem to reflect in the PDF engine (just the default folder for opening files), and the "File" settings in "Export Setup" don't seem to get saved with the setup profile. Those file/location settings stick around until close an reopen the software though, at least. I do also like the idea that someone mentioned where it should be a project-based setting instead of a global one, so that you can set each file / project to export to their own PDF folder.
