The NEC requires that receptacle demand load to be calculated as follows: 100% for the first 10,000VA and 50% for the remainder. The industry standard has always been to display this information as two separate line-items on electrical panel schedules:
Load Classification Connected Load Demand Factor Demand Load
Receptacle 10,000VA 100% 10,000VA
Receptacle 3,040VA 50% 1,520VA
Revit displays the information on the panel schedules in a single line, like this:
Receptacle 13,040VA 88.34% 11,520VA
While the calculation is correct, the way that it is displayed does not convey that the calculation has complied to the NEC requirement. We have been asked on multiple projects to display the receptacle demand load calculation as two separate line items on each panel schedule. As a result, we have had to export our Revit Panel Schedules to excel, to manually change the way that this information is displayed, in order to appease plan-checkers, costing us a lot of time and labor doing rework. This makes using Revit smart-circuiting unfeasible for many of our projects.
Revit should display this information in a way that is intuitive, and consistent with the industry accepted presentation of demand load calculations on panelboard schedules.
