This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
OPTION FOR AUTO-CAPITALIZATION
MANY ARCHITECTS USE ALL-CAPS ON DETAILS AND DRAWINGS FOR CLARITY.
CURRENTLY, A REVIT USER MUST MANUALLY TURN CAPS LOCK ON AND OFF VIA KEYBOARD.
BECAUSE REVIT USERS ARE TYPICALLY WORKING BETWEEN REVIT, EMAIL, TEAMS, ETC, TO COMMUNICATE WITH TEAM MEMBERS, WE OFTEN FIND OURSELVES WRITING EMAILS OR OTHER PROJECT CORRESPONDENCE IN ALL CAPS, WHICH IS OFTEN INAPPROPRIATE, AND WE OFTEN HAVE TO CLARIFY THAT WE ARE NOT YELLING.
IT WOULD BE NICE IF THERE WAS A FUNCTION WITHIN REVIT TO TOGGLE AUTO-CAPITALIZATION WHEN TYPING IN SHEETS. ADOBE INDESIGN CURRENTLY HAS A SIMILAR FUNCTION THAT WORKS WELL.
(NOT YELLING).
11 Comments
francfiles
I don't know if I understand your statement correctly but we have this option in Revit.
samuelsanf
All caps is not for clarity, is hard to read (because of that I decide to not read your entire post). If used, should be only in small notes.
It's only used because of traditions, when the drawing where made by hand and templates it increase the consitency to the letters.
Currently there are typefaces that looks like all caps, E.G.: Technic.
adobbertin
@francfiles Thank you! That is helpful, but not quite what I'm suggesting:
The capability you've mentioned requires a user to select into an existing text box that is currently not in all caps in order to change it. This workflow works only for a single text instance at a time and doesn't address the bigger workflow issue of a user constantly having to toggle caps lock on and off when working between programs.
The capability I'm requesting is more like the automated feature found in Adobe InDesign, where a user can specify that all text on a sheet (or within a template) will have all caps text, so when you add or modify text on such a sheet, the text automatically is all caps without having to toggle the caps lock key. Said another way, Revit would "know" through a setting that all text on a certain sheet should be capitalized so a user would not have to hit caps lock to write in all caps. This could be a setting that could be toggled in the annotate tab on the navigation bar, and would automatically apply to all text on that sheet. I think this capability could be one useful way that Autodesk could automate documentation, which I understand is a company-wide goal.
francfiles
Like an automated global setting that every time you're in Revit, text will always be typed in upper case. I totally agree with this proposal. I have to say, we encounter the exact same scenario so I sent out an email explaining that I'm working in Revit and not yelling.
adobbertin
@samuelsanf Architects use all caps as an industry standard because lowercase letters often look very similar to each other in different orientations. For example, the letters "p" "b" and "d" are the same shape in different orientations. If you can imagine the word "up" written in lower case will look like "dn" when it is rotated 180 degrees, which is not clear at all! All capitalized letters are visually distinct and can be understood in any orientation (same example: UP vs DN will not get confused).
samuelsanf
@adobbertin So we need to found new glyph for 6 and 9 because someone can't figure out if is holding the drawing upsidedown?
samuelsanf
But I get the idea, I would find helpfull if Revit had the All Caps options for Text notes Families and Schedules (appearance tab) but not for all the program (as it have for Bold, Italic, Underline)
adobbertin
@samuelsanf Can you clarify your argument on the 6 vs 9 comment? Please remember that the industry standard (and the workflow problem I raise) remains whether or not you agree with it.
The solution to bring the "all caps" option into the text type is interesting! I think that could work. However, it could also result in a proliferation of text types and if someone toggles that on and off for a particular existing text type, it could change text in unintended locations. What about using the same toggle you suggest, but on a per sheet basis? (having the check box in the sheet properties, for example) That seems more controlled from a documentation standpoint.
samuelsanf
Not agree. Someone that wants all the text in caps, only have to mark the hypothetical checkbox for all cap in the text note types already have in the project.
But, I refer back again. typeface Technic looks like caps in lowercase.... so, you only need to use a similar font.
There are Ideas I considers priority for text notes, like "element properties" and "view references inside text notes"
james.levieux
I think an "All Caps" type property would work perfectly!
BMillarBCG25
There is a key board shortcut to change to all caps after typing, or just capitalize the starting letter of every word,  which is what I prefer:  Shift-F3 is a life saver.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
