multi-line text and text with background mask
I would like a multi-line text menu identical to what is in autocad, including the options drop down and the symbols.
I know with Revit that within each text style I can choose opaque or transparent, but opaque only applies to the area of the text itself. I would like a background mask identical to what is in autocad that covers the entire area of the text box.
11 Comments
wr.marshall
The ability to specify if the bordered/boxed area is opaque or transparent. Currently Text can be set to opaque but area between text and border is transparent.
Tags (3)
wr.marshall
Tags (3)
wr.marshall
wr.marshall
The ability to specify if the bordered/boxed area is opaque or transparent. Currently Text can be set to opaque but area between text and border is transparent. The should probably be an option too for extending the opaque option beyond the border outline to give border a little breathing room.
Tags (3)
wr.marshall
sorry for spamming. was having problems uploading idea. @kimberly_fuhrman-jones please delete this post.
wr.marshall
sorry for spamming. was having problems uploading idea. @kimberly_fuhrman-jones please delete this post. hence duplicate wish
wr.marshall
sorry for spamming. was having problems uploading idea. @kimberly_fuhrman-jones please delete this post. hence duplicate idea/wish
@wr.marshall , Thank you. I've notified the moderators.
wr.marshall
regarding symbols you can find them when editing text as below screenshot. However this doesn't work if editing dimensions
As for opaque text, please see my idea here and vote for
Border/Boxed Text Opaque Option - Autodesk Community
apologies about the duplicate posts in this idea, I was having issues uploading it on the day
Please ask @kimberly_fuhrman-jones  to combine your idea with the opaque idea I created as the same.
And see this idea for multi line parameters
multi-line text parameter formatting options - Autodesk Community
MOR-ConorMacken
In edit mode, the background runs out to the border (at least for the border offset I'm using) and it looks SOOOOO much better.
wr.marshall
