More than 4 sorting and grouping criteria in a schedule
47 Comments
laurence_uy_eq
Any updates for this requst? It's been a decade since this was requested, and no signs of implementation is available. Please update.
rcrdzmmrmnn
I think we can all agree that if the view schedule filters behave like the View filters, it would solve all those problems.
In a API point of view, they both already inherit from the same class (View Class)
Schedule Views have this hierarchy :View Class -> TableView Class -> ViewSchedule Class
That should at least minimize the work in some sorts for the Revit DEV Team.
Schedule Filters similar to View Filters - Autodesk Community
stevemartin32N3Q
This has been needed for a long time, please implement this!  More times than not, I just need one more sorting category and my schedule would come out perfect.
mirhadi
Do you guys need help with it? shall we write the code for you?😤
alexandr.rosca
We are a decade into this suggestion. Autodesk please see to it! Maybe there is intention to add it with a bigger overhaul of schedules (to behave more like a spreadsheet editor) but this simple Sorting/Grouping option should be implemented ASAP regardless.
yuki.scharf
Increase the Number of Sorting/Grouping Levels Available in Schedules
Description
This request has been raised by Japanese Revit users regarding the Sorting/Grouping settings in schedules.
See the post :
https://forums.autodesk.com/t5/revit-aidia-ri-ben-yuforamu/ji-ji-biaono-bingbi-tie-fang-fa-wo-zengya...
Currently, Revit schedules allow only four sorting/grouping levels in the Sorting/Grouping tab. We would like this limit to be increased so schedules can be organized more precisely for documentation, quantity takeoff, and BIM-based workflows.
Request
Please increase the number of available sorting/grouping levels in schedule properties from the current limit of four to a higher number, such as seven or more.
This would allow users to create more accurate and flexible schedule sorting structures without relying on workarounds.
Rationale
Increasing the number of sorting/grouping levels would improve schedule usability and enable more precise data organization.
For example, allowing more levels would help users:
  • Create more detailed and accurate schedule sorting structures
  • Better organize quantities and classification data
  • Support BIM-based quantity takeoff and BIM 5D workflows more effectively
The current limit of four is often not sufficient for real project requirements, especially when multiple classification or breakdown conditions are needed.
eskilK3B2M
Community Visitor
Yes please!
I want to (for example) sort all my doors with all their different parameters (with, height, wall thickness, fire rating, sound reduction, fittings, etc.) before I give the doors their ID:s (Type Mark).
If this is impossible for Autodesk to figure out, maybe there is a plug-in that can help with this task?
(This is already possible in ArchiCAD b.t.w.)
