Schedule Filters similar to View Filters
Please implement the filtering method used in view filters for schedule filters. I've seen so many similar ideas: Like "OR" filters, ability to create more filters than the defined in the schedule, and others.
If it were implemented like the view filters, it would solve all those issues, and many more. I mean, so many schedules are used for data control and project model healthy, and what better way to achieve this than to being able to use the same filters in both views and schedules.
6 Comments
rtg_mep01
A very good implementation is also to use certain syntax, like containing "A;B;C;D", to filter parameters separated by ";".
Rafael_MartinezV
And add more flexibility to the conditional formatting in the "Format" tab.
The Revit schedules should behave more like excel.
barskyd
Yes exactly! Autodesk please get ChatGPT to program this for you if you can't figure it out after all these years.
hwo_osa
I'm jumping in on this too.
Having schedule filters act in the same way as the view filters would be extremely handy and also very logical from a UX perspective.
_mames
This is so long overdue its ridiculous
