Model Text Width Factor
Please allow control of the width factor in model text similar to how it is controlled in annotative text. The reason for this is model text is often used for signage which doesn't always follow a font's specific character spacing.
Thank you.
12 Comments
scbunker
Please allow us to change the width factor for model text. While you're at it, allow us to underline as well.
Thanks.
krzystoff
A great idea.  We should also be able to make the model text a VOID element as well, so they can be used to cut wall faces (bas-relief), which we do for every project (currently we have to trace the font manually with a void extrusion).
scbunker
+1 for void model text! Thanks @krzystoff!
bill_gilliss
In addition to Width Factor, which affects the overall width of the letters and the spaces between them, let's  add
  • Tracking, which controls the overall spacing between letters and words without affecting the width of individual letters
  • Kerning, which controls the spacing between any two letters.
I find that I usually need to create a separate piece of model text for each letter to be able to control spacing adequately, grouping them afterwards.
jkidder
It would be helpful if model text would also be visible at very thin dimensions (1/16" or 0) - I'd like to use it for signage that's available in all views.  Decals don't work because they take too much time to create/place, and also can't be visible in hidden line mode.
DGraham3
@bill_gilliss These more specific settings would be great additions.
I think it might be prudent to keep more advanced settings such as these under a 'Fonts' manager separate from the text type properties, similar to line styles and patterns, as these shouldn't be readily adjusted.
L_Lu_BIM
In addition, please allow vertical alignment of Model Text same as text annotation.
kaylaE3NQG
I agree with all of these!
AAlsarhanGL73L
Community Visitor
following up on this comment, can we change the depth factor for the model text in revit 23?
Ric_Weber
@kimberly_fuhrman-jones This idea should be combined with https://forums.autodesk.com/t5/revit-ideas/width-factor-for-model-text/idi-p/8018400 as it is the first one of the two.  Thank you!
Ric_Weber
Changing the width factor changes the width of each individual character.... which is good.  But I think when it comes to model text we also would want a way to change the distance between characters by a percentage as well.  I think that would in-fact be more important.  So we'd have Width Factor and add Space Width Factor as well.  It would also be a percentage type number just like the Width Factor is.
MiWolff
