Model Filled Regions (Multi-View Filled Regions)
In Autodesk Revit, filled regions are currently view-specific, which leads to repeated drafting, inconsistencies, and extra coordination effort when the same graphic is required in multiple views.
This idea proposes a new element type: Model Filled Regions.
Model Filled Regions would behave like standard filled regions (sketch-based, using drafting patterns), but instead of being limited to a single view, they would be visible across multiple views, similar to how model lines differ from detail lines.
Key Features
  • Multi-view visibility
    A single filled region is visible in all views that intersect its host plane.
  • Edit anywhere = update everywhere
    Changes made in any view update the element globally across all views.
  • Sketch-based workflow
    Created and edited like standard filled regions (no new tools required).
  • Plane-based hosting
    Hosted to:
    • Levels
    • Work planes
    • Reference planes
  • Optional visibility override
    Parameter: “Ignore host level for visibility”
    Allows the region to be shown across multiple levels regardless of view range.
  • Uses drafting fill patterns
    Maintains current behavior with view-dependent scaling.
  • Dedicated category
    Controlled via Visibility/Graphics under a new category:
  • Non-rendering
    These elements are purely for documentation and are never visible in rendered views.
  • Conversion tools
    Ability to convert:
    • Detail Filled Region → Model Filled Region
    • Model Filled Region → Detail Filled Region
Problem This Solves
Currently, repeating filled regions across views requires:
  • Copying and pasting
  • Grouping
  • Redrawing
This leads to:
  • Inconsistencies between views
  • Increased drafting time
  • Coordination errors
Why This Fits Revit
This follows an existing and familiar pattern in Revit:
  • Detail Lines → Model Lines
  • Detail Components → Model Components
  • Filled Regions → Model Filled Regions (proposed)
It introduces no new paradigm, only extends existing behavior to improve efficiency.
Summary
Model Filled Regions would provide a simple, lightweight way to create consistent 2D graphics across multiple views, reducing duplication while keeping the flexibility of filled regions.
2 Comments
MiWolff
But would this not qualify as a thin floor or ceiling? Or a thin wall if required in a section or elevation? You can even copy boundary sketches from one over to the other.
ks2_wmb
Oh no, this is an AI slop request.
