Several categories are missing <Hidden Lines>—this is essential for proper coordination with other models to work 100%.
It’s also messy that <Hidden Lines> in Object Styles do not automatically correspond with <Hidden Lines> in Line Styles.
Even worse, Autodesk’s default template assigns a dashed line pattern to <Hidden Lines>.
All subcategories in Object Styles that are tied to specific Revit functions, such as <Hidden Lines>, <Center Line>, etc., should start with < and end with >.
These should then be controlled via Line Styles to prevent mixing different line patterns.
