Measure in 3D
Measure in 3D
I would like to be able to use the measure tool in 3D views. For reference: EXACTLY the same way as in SketchUp.
57 Comments
filip.kabelis
it's been 5 freakin years and this is still not implemented... what the  hell autodesk? it's essential for proper modelling using 3D views.
why do I have to pay for some camillion plugin when it should be one of the essential tools? and please make it work in group mode also.
glennovits
Now its 2021 and measure tool in 3D is still nowhere to be found? I'm sure Autodesk and the Revit dev team has a lot on their plates - but just wanted to check in and let you know that users still wants this feature 😉
GGMSU
@glennovits
It's pretty sad.
filip.kabelis
Neither in 2022, maybe in 2027?
admin47
This seems to be such a basic thing-why can't you sort it Autodesk?   The only solution seems to be to buy a plug in. If I did that every time I wanted a basic thing I would spend double on Revit that we already do. At nearly £3K a year it is cripplingly expensive as it is..
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our Revit Public Roadmap. Thanks for the suggestion!
The Factory
paolomod3nese
Hi. Try the plugin 3DMeasure for revit at camilion.eu
Teodor.Nilson
Give us "measure in 3d" please! It should be as simple as pressing one key.
When I started using Revit the lack of this feature just blew my mind. I still can't wrap my head around that Autodesk built a 3D collaborative modelling environment without giving users the ability to check the relative position of objects in 3D space at a glance. I mean, Revit must know where the objects are already, right?
This functionality is super useful, not just for fluffy conceptual design modelling, but also for checking the location of 3D models from consultants which otherwise are more time consuming to get to display correctly in plan or section views.
paolomod3nese
Hi!
You can download this plugin to measure in 3d and check coordinates which
will be free starting february!
www.camilion.eu/en/apps/3DMeasure
We are pleased to say that this has been implemented in Revit 2023! Thank you for your contribution to improving Revit!
-The Factory
norbert_palumbo
Great idea!
davidsdanverRQHHN
Community Visitor
Currently, Revit makes it difficult to perform quick measurements in 3D views. The lack of a native "tape measure" tool means users must rely on workarounds (section boxes, temporary 2D dimensions, reference planes, or exporting to Navisworks). This limitation slows down workflows, adds unnecessary clicks, and often pushes teams outside of Revit just to confirm simple dimensions like clearances between pipes, ductwork, or equipment. A light 3D measurement tool, similar to Navisworks or SketchUp, would save hours of productivity. Keep users inside Revit rather than exporting. Reduce frustration for modelers, coordinators, and reviewers.
Ric_Weber
I'm in Revit 2024 and I can measure in a 3d view...  I forget which version they added that, but is that what you're referring to?  What version are you using?
davidsdanverRQHHN
Community Visitor
Thanks for pointing that out! I’m on Revit 2024 as well, and yes, I know
you can create dimensions in a 3D view if you enable annotations or even
use the existing Reference/Aligned Dimension tools. But that’s not what I
mean.
What I’m asking for is a simple measurement tool in 3D that includes
snapping to edges, corners, and faces, which would be lightweight for quick
one-off checks and similar to the “Measure” tool found in Navisworks or
SketchUp. Like below.
[image: image.png]
The current workflow (placing dimensions or reference planes) feels too
heavy when all you want to do is check a clearance or verify a distance. A
true snap-based measurement tool in 3D would really improve productivity.
Does anyone know if Revit 2025 added this, or is it still only the
dimension workaround?
Ric_Weber
You CAN use the Measure Between Two References tool in 3D.  It will snap to the 3d model.  You can even use the chain option and measure along several connected paths.  I'm fairly sure this is what you're talking about and it's already there in the Modify tab, Measure panel.
MiWolff
r25.4: Measuring in 3D does not snap to levels. Correct that, please.
