Match Instance Properties
I give Revit training on a regular basis, and get often the question is there a possibility to Match the Instance Properties. I then tell my trainees that they can select all the items they want to modify and specify the instance properties in one go. But it seems more logic, especially when you have a background using AutoCAD that there would be a tool to match all the properties at once.
I do wonder why there is no way to match all the Instance Properties just like you can do match Type Properties. Off-course the idea is simple, but if you would be able to match the instance properties for system families (wall/floors/roofs/ceilings etc.) to get started, that would make a big difference.
Hope that you can recognize yourself in this idea.
With kind regards,
Kelly Pelzer
1 Comment
germanperales
A really good idea. Thanks.
