お知らせ
キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
Match Instance Properties
I give Revit training on a regular basis, and get often the question is there a possibility to Match the Instance Properties. I then tell my trainees that they can select all the items they want to modify and specify the instance properties in one go. But it seems more logic, especially when you have a background using AutoCAD that there would be a tool to match all the properties at once.
I do wonder why there is no way to match all the Instance Properties just like you can do match Type Properties. Off-course the idea is simple, but if you would be able to match the instance properties for system families (wall/floors/roofs/ceilings etc.) to get started, that would make a big difference.
Hope that you can recognize yourself in this idea.
With kind regards,
Kelly Pelzer
1件のコメント
germanperales
A really good idea. Thanks.
お探しの情報が見つからないときは、コミュニティで質問しましょう。困っている人がいたら、情報を教えてあげましょう。
アイデアを提出
