Make View Rewind tool discoverable
There's a super-useful tool named Rewind that works like an Undo just for Zooming.
But most people aren't even aware that it exists because it's hidden under the seldom-used Steering Wheel (which itself is hidden under the Navigation Bar) and therefore, not very "discoverable"
Adding Rewind to the View Tab of the Ribbon - perhaps on the "Windows" Panel, alongside Switch Windows and Tile Windows - and allowing it to have a Keyboard Shortcut would be a GREAT time-saver and make it simpler (possible?) for people to find this very useful tool
This Idea has been resubmitted from past Archived Idea:
https://forums.autodesk.com/t5/revit-ideas/add-rewind-to-the-ribbon/idi-p/6827494
5 Comments
dplumb_BWBR
With the uncropped Perspective Views in 2019, this even more needs to made available.
I'm curious why just adding a Keyboard Shortcut to this tool seems to be difficult to accomplish.
Tupaia
A big, fat +1 from my side!!
Basam.Yousif
You got my vote, Dave!
Leszek_Golubinski
It is present in context menu (2019.2) as 'Previous Pan/Zoom' and 'Next Pan/Zoom'.
dplumb_BWBR
That's not quite the same as the Rewind Tool
Yes, it does step back through your previous Zooms and Pans, but you have to type in ZP for EACH instance.
Zoom Previous does not have a corresponding "Zoom Next" or "undo"
You can go back and forth with Rewind.
AND with the Rewind tool, you get a graphic showing you what the zoom will look like
