Linework Tool - Foreground / Background Option
When adjusting lineweights in say an elevation, the behavior currently is that the adjusted line will jump to the foreground even if there is an object in front of a portion of that line. It would be valuable to have a foreground / background toggle for the linework tool so foreground elements continue to mask an overridden line similar to how it behaves when overriding projection lines through V/G or the view template.
1 Comment
Mike.FORM
I agree it would be nice to just have a toggle to either ignore modeled elements or not. Having to use the linework tool multiple times on one line and adjusting the end grips to make it so the line does not draw in front of elements can become quite tedious.
