Lightning protection and earthing system in Revit
In most modern buildings, the electrical planning includes a lightning protection and earthing system. Unfortunately, the necessary families and functions for lightning protection are missing in Revit.
Since the complete lightning protection with all its components would be far too extensive, complex and detailed, I would like to have the basics (can also be extended later) on lightning protection and earthing added to Revit.
For the beginning the following is needed:
  • A new model category: "Lightning Protection and Earthing System" + a new annotation category
  • Two new system family "round wires" and "earthing strips", with the following properties:
    • Freely Placeable / Editable in any view (floor plan, section view, elevation view, 3D, ...)
    • Flexible / bendable (similar to SPLINE), no rigid parts (Maybe a drawing behavior similar to the existing families "beam" or "flexible pipe")
    • Drawable in all directions
    • Relatively tight bending radii possible
    • Adjustable dimensions (diameter for wires and width/height for strips)
  • Fittings for the system families: T-piece, cross piece and union piece
  • Components: air-termination rod, air-termination conductor, earthing terminal, earth rod and test joint (families that can be connected directly to round wires)
When it comes to the implementation and you need precise and detailed information on how the lightning protection should/could be in Revit (Functionality, appearance, etc.), please contact me and I will describe it as detailed as possible.
Attached: Pictures and practical examples
More information about lightning protection and its components:
http://www.dehn-usa.com/en-us/lightning-protection-earthing/air-termination-system-down-conductor-is...
8 Comments
hungan9E6K3
Hi dominikleuchter,
I am modelling in one project need lightning protection system, we designed by 2D before then import drawing to Revit model so we recognize its not good solution when architecture model has changed and we can not control the model and equipment.
Here I found the link show some thing how to implement but I can not found BIM manufacture of equipment.
https://www.youtube.com/watch?v=9ejeHAfamqM
Can you plz help by send me all family to create lightning bounding system?
Many Thanks!
MariuszZygmunt
Hey
hungan9E6K3
On the move shows that you have a grounding device and lightning protection - where to download them from?
Mehmet.KARLIOGLU
The family part of this issue is simple for me. What we need here is that the grounding system is defined in Revit. In this case, coordination with other systems will be easy. Otherwise, we have to produce both dwg and revit combination sheets.
jone.foss
Hello, is there any updates in Revit regarding this?
Recently started with revit and we have a project were we need to apply earthing rods, earting wires to every rod etc.
But i do not find any families, objects that is made for this use.
Phil-Pleiss
Want to "bump" this idea. Currently we have been using the category "Nurse Call Devices" for Lighting and Grounding "L&G" elements. This is so that we can turn them on/off under the Model Categories as most of the power stuff uses the Electrical Fixtures Model Category. L&G devices since they are typically shown on their own drawing. The main need here is a Model Category for Lightning and Grounding (or "Lightning Protection and Earthing Systems").
marleneguerta
Has anyone got update if this was solved? Still looking for solution with the same problem with regards to Lightning protection and earthing system stuff
stuart_plunkett
I've been using using conduits to model the conductors (using a new conduit system size) then using the parameter "Service Type" as "Lightning Protection" to filter all the other conduit types out of the drawing. for electrical fixtures I use a shared instance parameter called "unit service type" and filter electrical fixtures that way. works pretty good so far.
