Level/Spot Elevation that can read both Project Base Point and Survey Point
It would be incredibly helpful to update Levels and Spot Elevations to have the ability to show alternate units - similar to dimensions - that can read from both the Project Base Point and Survey Point. For example, if the Project Base Point is set to be 102' above the Survey Point, the label could show:
0' - 0" (+102.00')
or something along these lines.
22 Comments
FinearcLtd
Sophisticated Level tagging is needed. Being able to refer level tags in plan to several floor layers (top and bottom of concrete, top of concrete and top of tiling, etc.)Level tagging that shows relation to survey base point and project base point together. Both is plan and in section. Currently some of these are impossible to create and in other cases it is required to create them separately. Revit can do better!
BethanyPritchard
Just to be clear, Autodesk what we need is for level heads to be able to display BOTH the project base point elevation and the survey point elevation in the same tag.  Currently the settings in the level system family force us to choose elevation base to be one or the other.
Some projects require seeing both the project and survey elevation at the same time for construction. This should be made available for levels, with a prefix and suffix option for both project elevation and survey elevation. Inputing survey elevations as text increases error if any changes are made during the design process.
eramoy
I agree that this feature should be added to Revit.
However, here's a not terrible workaround I'm using. I've added a calculated parameter to the tag for the survey elevation. This adds the survey elevation at project 0 to the project elevation at any tag. You need to change the calculation in each project, but once it's in a project, it will calculate all the surveys automatically and is unlikely to change (unless you change where project 0 is).
samuelsanf
samuelsanf
Totally agree!
tolga.isikyildiz
I use two exact same elevation tags for this, one reads height from the survey 0.00*,  other from the project O.00. Then place one of each exact on top and adjust bracets and offset values so they appear as desired. Generally, it shouldnt be done for all the elevations, just a few would be enough.
*(Survey elevation tag might had been done without elevation sign, but then you may loose where it is dedicated to.)
But still this would be a good improvement.
jan
Many (most) of our projects require tracking both the absolute elevation (eg Above Sea Level) AND the relative elevation (to ground level). Revit offers a great way to set up both those references, where the Survey Origin sits at absolute survey zero (eg sea level) and the Project Base Point sits at the project's ground level. However, Levels (and for that matter Spot Elevations), do not allow tracking both those references in a single Level marker. The 'Elevation Base' Type Parameter decides which, and there is no second/alternate option.
I bet there are Revit-apologists out there who claim that this should not be possible for one or the other reason. I'm not even going to go there.
I also know there are workarounds: (1) adding a Spot Elevation to each marker in each view (no thank you), (2) duplicating Levels (not a chance in hell), or (3) adding a Shared Parameter to the Level Heads for tracking the second reference and using a Dynamo script to populate the values.
This last workaround is what we currently do, but as we know pushing values through a button/script is no substitute for Revit live-updating those values and letting our designers focus on other things.
Tags (4)
Hi, @jan ,
Here are some similar Ideas:
Levels Project and Survey Elevation - Autodesk Community
Level/Spot Elevation that can read both Project Base Point and Survey Point - Autodesk Community
Level tagging - Autodesk Community
I'll work on combining these to give the votes a boost!
Thank you for your Idea submission!
-Kimberly
jan
hm, I did check if someone had already posted this, but it didn't show up. thanks Kimberly!
@jan  You're welcome! 😊
mmarcarelliNX
@kimberly_fuhrman-jones thanks for consolidating all of these ideas into one. Does Autodesk see this as an idea with (currently) 62 Votes, or 87 Votes (62+20+4+1) ??
Has there been any development with this issue? Thanks!
Hi, @mmarcarelliNX ,
The 62 votes includes the 20, 4 and 1. Votes are merged when the posts are merged. Hope this helps!
-Kimberly
Michael_Buttery
In addition to showing multiple datums I would add the ability to use the View Associated Level, or the Reference Element (tag host) Level as datums.
This would be very useful when documenting local falls in floors, roofs, ramps etc.
EDIT: This can be done by setting the Type Elevation Base to 'Internal Origin' which then allows the relative base be set on a per instance basis
nicoleYYMWH
Community Visitor
It is currently impossibly to have a level head reflect both an elevation from project zero and a survey elevation. We have to manually add this in on every project. We would ideally like our level heads to say the project elevation then survey elevation in parentheses with a plus sign like this: +10'-0" (+250'.00). This requires having flexibility to change unit rounding, unit type and prefixes and suffixes for both types of elevations.
A workaround is to use the spot elevation tool, but this cannot add both a prefix and a suffix (why???) as a type parameter, only an instance parameter, and having adding them on each elevation point cancels out the time savings. Please update both. There are instances where I would like to use the spot elevation to reference both elevations in that same format as well.
Tags (4)
tjones1410
I completely support this idea.
I created a level head family with shared parameters to facilitate the desired result in the meantime.  It does require manual entry of the survey elevation as a type parameter for the family, but it only needs to be entered once for the level type and only changed if the survey elevation changes.  Much simpler than a Dynamo script IMO.
Parameters that begin with underscore are shared, those that begin with a lowercase "x" are calculated parameters, sentence case are system parameters.
Note the xEND parameter is so the end parenthesis shows up if the _TEXT parameter is empty.
shadkhan00786
Community Visitor
Can you please send your family to me ?
@tjones1410
tjones1410
I would be happy to if someone can tell me how to upload the file.  This board does not allow uploading an .rfa file or apparently anything but image or video files.
shadkhan00786
Community Visitor
taaviSWPX2
This would be a really useful feature. Autodesk, please implement this!
Right now we have to jump through multiple hoops to get this:
It would be quite an easy fix to expose both the elevation relative to Project Base Point and Survey Point in the Level head tag parameters and let the user add both to the tag if needed.
