Element Id's selectable in Dynamo Player Output
The element IDs which are visible in the Dynamo Player 'edit input' section should be set to a selectable method in order to perform same as the function of a Dynamo Watch node. Hence the user will be able to click on the required element ID and navigate to the position of the element.
3 Comments
sakwet
Selectable and highlighted in view simultaneously will be of great advantage
This is exactly what I also find totally useful! Some colleagues cannot interact with Dynamo workspace ( they are afraid of it :D), therefore a simple dynamic click on the element ID from Dynamo Player list would be of a great advantage.
Thans in advance!
sakwet
Make elements selectable in Dynamo Player output/input, thus after running a script a user can click on the element's ID and directly go to the element in a preferred view
Tags (1)
