cancelar
Mostrando los resultados de
Quiere decir:
Element Id's selectable in Dynamo Player Output
The element IDs which are visible in the Dynamo Player 'edit input' section should be set to a selectable method in order to perform same as the function of a Dynamo Watch node. Hence the user will be able to click on the required element ID and navigate to the position of the element.
2 Comentarios
sakwet
Selectable and highlighted in view simultaneously will be of great advantage
No aplicable
This is exactly what I also find totally useful! Some colleagues cannot interact with Dynamo workspace ( they are afraid of it :D), therefore a simple dynamic click on the element ID from Dynamo Player list would be of a great advantage.
Thans in advance!
Enviar idea
