Element Id's selectable in Dynamo Player Output
The element IDs which are visible in the Dynamo Player 'edit input' section should be set to a selectable method in order to perform same as the function of a Dynamo Watch node. Hence the user will be able to click on the required element ID and navigate to the position of the element.
Comentarios
Selectable and highlighted in view simultaneously will be of great advantage
This is exactly what I also find totally useful! Some colleagues cannot interact with Dynamo workspace ( they are afraid of it :D), therefore a simple dynamic click on the element ID from Dynamo Player list would be of a great advantage.
Thans in advance!
