Insert multiple PDF pages
Currently to insert (or link) a PDF page, one must do so for each page individually.
For example, for a 6 page PDF, in which each page is desired to be placed on a sheet, you have to repeat the following steps:
Insert/Link PDF
Select the page
Click insert
Place
It would be helpful to be able to select multiple pages, click insert, then place by clicking to place each sheet in succession. As is, this task is tedious.
2 Comments
kmanningTN4F5
Observer
Agreed. Even staying on the "Import PDF" window after placing would help, instead of having to restart the process from step one.
andrew_kephart
Observer
Yes, and it should be organized in an ordered grid. If you want the [X] number of pages to span from top-to-bottom, with [X] number of columns from left-to-right within a boxed boundary in each sheet. Make this idea happen!
