Insert-Link Navis NWC files directly into Revit
It would be nice to be able to insert/link Navis NWC files directly into Revit. This would satify the need when you don't get Revit models from Owners or Outside consultants. The ability to bring the 3D geometry from NWC would be terrific. Right now we can only look at it all together in Navisworks following the modeling effort which is not very efficient
Thanks Smiley Happy
20 Comments
The AutoCAD 2016 feature of seeing a Navisworks or BIM360 model inside of AutoCAD is awesome. No, can we get that for Revit? That could possibly have shaved off hundred of hours of importing generic exploded PLant3D models back into Revit on one recent project. This would be a huge bonus for multi-platform design teams.
Tags (5)
SeanSpence
YES YES YES,
Quite often we only need something to rout against. NWC models are a fraction of the size of Revit models. having the ability to add an NWC in when we don't need all the extra stuff and processing that comes along with an attached Revit model would improve model performance substantially.
(We can do this now with a (dumb) 3D Cad file, but its an extra step. we already make the NWCs for clash detection in Navis. This feature would be very handy)
nwakeman
Agree! A two way street would be much more functional.
dgorsman
Given that NWD is more likely to be shared, as Freedom doesn't require a license, time-bombed, locked from re-publishing, etc., that format should also be available.  Even if NWD is the only Navisworks format supported if you can work with NWC then publishing to NWD is a small, if extra, step.
I fully endorse this idea
rchnorton
I'm going to strongly agree with the ability to link in NWC's. At present models some models for our current project contain in excess of 45 linked models to fully federate the design. The ability to use lightweight NWC's in place of Revit models would increase performance for both design and review.
YZhuang_Spectech
Recently, we have come across an issue where all disciplines submitted their Revit Models, and clash detection was run on them. The resulting files came back to us as a bunch of pictures which showed a clash between 2 objects, but didnt show where those objects where (20 floor building, couldnt tell the floor it was on, and no walls to show me a general area, just 2 objects and where they clashed), and a .nwd file (navisworks), and this is a software my company doesnt own. I looked high and low for a way to be able to import the .nwd file into my Revit Model so that I could directly locate the areas of concern, but to my suprise, there was nothing to be found.
In short, and option to import navisworks files would be HUGE for collaboration purposes, as well as modeling around these clashes in real time rather than having to run clash detection again to see if it fixed the problem. I believe this would be an extremely useful tool for most everyone who uses a collab between Revit and Navisworks.
Fully support your suggestion: It should be made possible by Autodesk that the clashes from Navisworks can be imported into Revit. I know for a fact that it works because private apps are around but not accessible unfortunately.
harlan_brumm
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
SeanSpence
RIGHT ON!! Thanks @apaupert & @harlan_brumm
rchnorton
Fantastic news! Now when can we expect the functionality to be added?
harlan_brumm
Hi Everyone,
I'm pleased to say that this idea is now implemented and available in Revit 2018.  You can learn more about it in the help here: http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-4E489B91-C1C6-4733-AC82-3CE639F6A07A  Thanks for your votes and ideas!
The Factory
SeanSpence
@harlan_brumm Why isn't there a Navis works Idea page? There are ideas that live on the revit idea page that are more suited to Navisworks that don't get the votes they deserve because they aren't accessible by the people using the software.
Would an idea in the Revit ideas to add a navisworks idea page get any attention from autodesk?
How about for old version revit ( 2015, 2016, 2017) ? How can I import nwc to revit 2015 or autodesk did not support ?
MiWolff
@harlan_brumm If you could measure things in linked coordination models you could actually call it coordination model. Right now you still have to get out of Revit and into Navisworks to check how much clear space there is under that duct that suddenly protruded from the ceiling.
harlan_brumm
Thanks @MiWolff for the comments.  Appreciate the  feedback about this functionality for sure.
SeanSpence
I am going through this right now. I have to jump back and forth to locate HUNDREDS of pieces of equipment from a navis works file generated by a competitors BIM software. (Its nice they use your software though for coordination) its very very tedious. But it is easier now that it is linked to Revit.
If we could click the elements and see their navisworks associated BIM Data along with the dimensioning, that would be an enormous help too. The Navis works file sure does help get their stuff in there. linking a process cad file that big into revit just crashes things. So big kudos to you @harlan_brumm and your team for making that happen in the first place. Us users a fickle people though... were never happy:) we want more!!! 🙂 Thanks again. NWD in RVT is a big game changer.
Tarek_K
Status changed to: Gathering Support
SeanSpence
@Tarek_K The original idea for this has already been implemented. there are other items though that were raised in the comments section of this tread that could be added as new enhancements. Is that why you revised it to Gathering support. I would think that it would be better to close this tread than to hope people will find the suggestions.
Tarek_K
