Improve performance when editing electrical circuits (adding ,removing parts..)
When we change/edit a circuit (by removing a symbol/fixture from a circuit and adding it to another, it takes very long). This depends on the number of symbols on the panel and gets slower logarthmic, not linear. At the end of the video I've attatched, you will see the difference. The same action is approx 20x faster because of removal of 2/3 of the symbols.
8 Comments
Martin__Schmid
Status changed to: Gathering Support
Hi @Thomasbsmits  thanks for the suggestion.  We are always looking for ways to improve the performance of the software.  Can you elaborate on under what scenarios you would have over 500 devices on a single circuit?
Thomasbsmits
Hi @Martin__Schmid, mainly within our non-residential projects. We're experiencing very slow preformance within the following project regarding to the "star" ceiling (Rotterdam ICC): https://zwartlichtvr.com/pano/ahoy/index.html
Martin__Schmid
Interesting!  @Thomasbsmits  could you please log a support ticket here?  It would be better for our team to evaluate this in the actual project if possible so that we can evaluate other dependencies that wouldn't be readily apparent in the basic example in your original post.
Thomasbsmits
Hi @Martin__Schmid, I've allready created a case (15198085) within our support portal. They've asked me to submit this issue at the idea station.
Martin__Schmid
@Thomasbsmits  Ergh, ok, thanks.. sorry for the crossed wires.  I'll follow up with the support folks.
kimberly.fuhrman
We are pleased to say that this has been implemented in Revit 2022.1! Thank you for your contribution to improving Revit!
-The Factory
Tarek_K
Tarek_K
Autodesk Customer Advisory Groups
