Image size export not consistent
Just got this problem for the first time working in Revit 2018.3.
When exporting perspectives to jpg in Revit that have the same dimension (in fact I usually just duplicate the camera and move it arround to create another view), they end up exported with slightly diferent pixel proportions.
My set size in Revit is 16x9cm by default and export with 5000 horizontal pixels.
The correct result should be 5000x2812 but sometimes (no idea why) the image is 5000x2825.
This diference is enough to be noticed when I insert the image in a ppt presentation file that as 16:9 proportion (so that the image is full frame).
I go the problem solved by sizing the image to 16x10cm and back to 16x9cm before exporting again, but it's stupid to be doing that to every image that got wrong (they are a lot, I use batch export for that), when it was a copy from the first.
Please fix this bug!
