Graphical Column Snapping and Dimensioning
Can we please have the ability to dimension the columns within the Graphical Column Schedule.
Also it would be nice to have the snap points for spot elevations accessible when copying a spot elevation from one column to the next.
Currently the snap points are available when placing a spot elevation but every time you place a spot elevation you need to click at minimum 2 times (if leader shoulder is turned off). With snap points available using the copy command that would mean you can place the first spot elevation using 2 clicks and then copy them to every other column with only one additional click per column.
When there are hundreds off columns this will save a lot off clicks and time by essentially cutting it in half.
My current schedule looks like this, with the column height reporting in the tag and the spot elevation showing real world elevation at the top.
