What happens currently?
- At present filled regions are only available in 2D family templates.
- We can add a masking region to a 3D family, but never a Filled Region.
- Ridiculous workflows are currently required to create parametric pattern options (especially for our plan
views) simply because the filled region tool is only available in 2D family templates. - We are also unable to import detail items in to 3D families (Another wish-list item, which I will log separately!) so we have no way of getting patterns into 3D families.
What we need, instead
- It would be very useful to be able to add a filled region into a family, especially in plan or elevation
views, where a solid white fill might be undesirable. - There are many times when a masking or filled region is more appropriate to create patterning
than using 3d geometry with material settings. - Teams need to be able to create BIM-Integrated presentation plans that do not need to be imported into Photoshop or another external product in order to add colour or pattern accents in plan or elevation views.
- Whilst we support the model focus in Revit (always) there are times when presentations are required that simply should not warrant complex filter rules and overrides that limit flexibility and alienate beginner to intermediate level staff.
- Please make pattern parameter instance and editable from project environment! We do not want to create different family types just to add a pattern or colour change to some items in a view. (That would be an insane workflow!)
- Please see attached images for more specific explanation.
PLEASE VOTE
1. For this functionality so that we can all avoid time-consuming and unnecessarily complex work-arounds when our projects require more flexibility in presentation.
2. For some other ideas (listed below) that may benefit your project teams too.
https://forums.autodesk.com/t5/revit-ideas/revit-masking-regions-not-responding-to-subcategory-visib...
THANKS SO MUCH! Michelle
