What happens currently?
- A masking or filled region can be assigned to a subcategory, but this assignment is meaningless
when the subcategory settings only control the visibility of the area outline line work and not the
fill area itself. - Note: This functionality request (of fills responding to subcategory visibility settings in a view) needs to be applied to both filled regions and masking regions.
What the industry needs, instead:
- Filled and masking regions need to be able to be assigned to a subcategory (both the sketch line
work and the region pattern area) and must also then respond (in its entirety) to any visibility
changes that are made to their associated subcategory using the Object Style or Visibility Graphics menu.
Impact on Revit users
- Masking regions cannot be used for floor or elevation representations on any element that may be required to be hidden at any point in a view that has a patterned floor or patterned wall. Thus, making masking regions as unusable/ useless in any company system that expects to be able to use subcategory visibility controls in their View Templates.
Autodesk's response to date to this request
- I have been told that this feature is "by design" however it should be clear from attached image examples that an alternate solution should be provided or that the development team re-think their stance on the matter.
- If the development team remain adamant that "Masking regions should always be displayed" and therefore should have no ability to be hidden using it's assigned subcategory then I think the Autodesk Development team needs to come up with a viable and alternate solution:
- E.g. Development team could enable Filled Regions to be added to all 3D family templates and allow us to have full visibility control and parametric pattern controls for the Filled regions in 3D families. (Separate Idea/request which I will be adding next) Please vote for that one too!
PLEASE FIX THIS OR PROVIDE AN ALTERNATIVE. THIS HAS BEEN A KNOWN ISSUE FOR FAR TOO LONG!
