Feature "including textures" for E-Transmit
I had a dream:
In the future it would be possible to collect all used texture maps into a single folder by using e-transmit.
please let this dream become true!
For sharing of the whole Revit Modell on different Workstation or for external use of the Modell this would be a great improvement!
Kind regards from Germany,
Bernhard Fetzer
10 Comments
GHASEM_ARIYANI
hi
When to transfer a project from one Computer to another Computer , are missing Textures or CAD Link and ... .
Etransmit plugin solves some problems , But the transfer of texture is still having problems. Because must be collected Texture Manually paths.
If add a bootom save material with texture In the Material Editor dialog or Save As Archive tools such as the 3D MAX It is very efficient.
I was surprised to find out that material texture images are not gathered up by the E-transmit process. Instead, they must be "manually copied".
This is a bit ridiculous, since it would involve making a list of used materials and then going to hunt for them manually. Even if your firm has a proper material library, this is an inefficient and error-prone workflow/endeavor.
I would add an option to gather up the materials and CAD files when using E-transmit. To be more precise, everything that is on this list should have an option to be included.
sasha.crotty
Status changed to: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
sasha.crotty
mileta_pejovic
We need ability to collect all project textures in order to transfer Revit project on multiple PCs and use custom made textures, stored in random (not Autodesk Shared material) folders. Ww also need this option in order to use the same textures in other Autodesk software (3ds max etc...)
Adobe video editing software have similar option - Collect files - all used files are collected and zipped in one file for easier transfer.
May dynamo be the workaround?
Like how families are stored in a project once you load them?Revit would greatly benefit from that.
ShineThrone
  1. Packing" Materials/Textures
Like blender pack
I want for other people revit file with textures !
B.Fetzer
Current status:
When transferring a project, the texture images of the materials used are not transferred.
Alternatively:
Texture images are collected in a separate folder called "Textures" and transferred along with the project.
Kind regards,
Bernhard
