Expand select all instances in view/project
Expand the select all instances in view/project command to more than one object.
32 Comments
Ability to Select All Instances during Few Elemnets Selected
samuelsanf
In AutoCAD you can select a Polyline and use the Select All Intances command, then select an Arc and use Select All Instances again without unselect the previous polyline, this command works with multiple object at time with no problem.
In Revit you only can use Select All Intances for an object a time. It will be nice if you can do a Select All Intances for various objects types at once.
Another thing is that in Revit you can't Select All Intances for annotations lines, I would appreciate to see this in future.
Tags (3)
Allow Select All instances in view and in project to apply to Line Styles.
A_MAQ
Ability to select all instances of model lines in project or views it will be a great features
Oh yes. This would make cleaning up redundant / replacing line styles so much easier.
Kimtaurus
This needs way more votes.
I've got a project with 100 or so views and changing (duplicate) line styles is an absolute hassle.
I've got to open every view to check and change style if necessary.
A_MAQ
totally agree with you , we are waiting a response from autodesk
Kimtaurus
I've found a similar Idea, maybe an administrator can merge these Ideas? @sasha.crotty ?
https://forums.autodesk.com/t5/revit-ideas/select-all-for-line-styles/idi-p/6866530
A_MAQ
Thanks @sasha.crotty
vanessa
It would be nice if we could right click on a specific linetype and "select all instances" in view instead of having to select everything and then filter them out.
Tags (2)
You, that would be real useful. This is related to my more general idea that encompasses this idea:
https://forums.autodesk.com/t5/revit-ideas/add-annotations-categories-to-view-filters/idi-p/7960096
-t
Kimtaurus
sabeel.shaik
This will save a lot of time for sure.
sabeel.shaik
I am eagerly waiting for auto desk to add this feature.
YES I 100% AGREE
roldham89U5G
YES!
Atafs
This would be absolutely helpful
Atafs
good Idea
awasyliw
For the sake of my sanity please give us the ability to select multiple object types and do a select all instances on them.
Some options on matching might also be nice (type/family/level/etc.)
Tags (2)
Intuos5
Also allow to use a window selection in Edit Group > Add detail group, instead of manually selecting the individual lines to be added.
