Existing Rooms in Demo Views
I understand that Demo is an action that exists in New Construction, but the industry as a whole usually tags existing rooms in Demolition plans - not New Construction rooms. This is due to the complete picture of an existing floor plan created by Existing to Remain elements + Demolished elements.
The only options we have come up with to fulfill this set requirement are either to overlay another view on the sheet containing only existing room tags, or to use a dummy tag (yuck!). Help us utilize the intelligence of Room information to benefit our set!
93 Comments
dplumb_BWBR
Please do a search before posting an Idea.
There are at least a dozen similar (if not identical) other posts that show up when searching for "Phase Rooms"
If the problem were resolved, then people wouldn't need to remind the developers to fix it.
dplumb_BWBR
That's not my point.
If there are 20 different posts about Room Phasing, then each individual post is likely to get 1/20 of the votes, and the overall concept doesn't seems that important.
This sire works by the number of votes EACH Idea gets. Not by the number of Ideas that are posted.
Just experienced this issue. Yes we need this, VERY VERY VERY practical
The existing phase rooms cannot be seen / tagged in newer phase! Man Sad
lejla.s
please note this one - it's  already under review:
https://forums.autodesk.com/t5/revit-ideas/rooms-from-previous-phases/idi-p/6348861
ambim
Please allow rooms to act like other model objects with phasing. For the very many of us who specialize in renovating existing buildings, the workflow is horrendous. See below.
- If I have an existing plan with existing rooms and I want to demo some walls for my new project, my demo plan would be set to "New Construction, Show Previous & Demo" with the walls being demo'd in New Construction phase. But two things happen here. 1) the rooms from my existing phase no longer exist, so I need to copy/paste them to the New Construction phase. This now double counts the rooms in the project with the same name and number, even though they are in different phases. It's also an additional step that should not be necessary because I have already created my existing rooms! 2) the demo'd walls effectively negate any room bounding that would occur, thus making room tagging of the 'existing' rooms useless.
Our internal workaround for this has been to create an existing floor plan set to the same scale as our demo plan, control the VG to only show rooms and room tags, and overlay that on the demo plan. This is a crazy workaround for a problem that seems shouldn't exist.
- Also, allow rooms to change phase after placement. Again, rooms being agnostic to phasing except on placement is not something that should occur. Just make rooms act like other model elements.
NWihnan
Please make rooms/spaces work like everything else in Revit. A room/space should be able to exist across phases. It should be possible to create a room/space and set the phase it is created and the phase it is to be demolished like all other objects or to create a space in the existing phase that is not demolished and exists in the new construction phase.
Tags (3)
Really hope this gets worked out - we do the same thing and it's just not right! It ruins schedules etc. as well as collaboration between consultants. Revit, help!
Autodesk, please to provide a parameter that allows rooms and spaces to be created/demolished per phase.
kylee.Feland
This could be as easy as a visibility tick box for each phase in the properties box. I can see there being issues for room area calculations in rooms that are in multiple phases but grow/shrink in size as walls are added or demolished... making room separation lines able to be phased could help with this.
Duplication of rooms, workarounds of a ton of extra views, and detail groups of room names wouldn't be required if rooms acted like every other model item in Revit.  This sets up all design professionals for mistakes.  This needs to be fixed - the rationale behind this is not based in industry practice and drawing production.  Existing rooms need to be shown in context just like existing walls and doors.  FIX THIS PLEASE!!
ADiVenere
Rooms are currently Phase specific. I need a phase that will show both existing and new construction Rooms/Room tags. It is very frustrating and causes a lot of problems when having to duplicate rooms from one phase to the next.
ADiVenere
Has any progress been made on this from the Autodesk team? It seems that it has more than enough support. As more projects are utilizing options to renovate existing buildings, we need the software to work with us.
K-Eastman
I can't believe this is still a problem in 2020. This is an old post but I'm trying to add votes to a post that is established to get as many votes as possible. I wish when you go to set a post here using key words it would pop up previous posts that could match yours so we don't get 10 posts on the same idea so the votes don't get spread around.
AMBrown29
I am working on a 200 million dollar project with close to 25 phases and I have spent a disgusting amount of time dealing with the multitude of issues and complications from this one issue in Revit. In my research, this one issue has been commented on for close to 10 years and Autodesk has still not addressed it. I have voted on this comment and I will vote on any other I can find, as well as posting my own comment with the suggestion that others do the same. The only way to get Autodesk's attention is to be the squeaky wheel!!!
AMBrown29
There are already many, many request made over many years of the programs existence to have room phasing.  I have commented and voted on several of these already, and I suggest that others do the same. There does not seem to be any reason not to have rooms multi phased, but there are numerous and extremely complicated problems that would be solved by this one modification.  For one, existing rooms tags could be added. also, rooms would not have to be copied from one phase to another and renumbering would not be so complicated. I am working on a very large project with close to 25 phases and this one issue has become the bane of my existence.
Please, I urge you to vote for the most popular suggestions for this topic so that maybe we can get AutoDesk's attention and once and for all get this problem with the program fixed.
Tags (1)
mmeinert
Ditto for Spaces please.
NateBrush
I'll add a comment on phasing that I've added on other Ideas. The phasing logic needs to be re-written around the real world logic of phasing and renovation, rather than a code/graphics logic. In Revit a family is existing from a previous phase or new. An existing object getting demolished is treated as part of the new phase. A room doesn't follow the same logic.
Reality is that rooms and objects to be demolished exist as part of the existing phase. Their continuity ends at the end of existing phase, not the new phase. For example, I might bulldoze an existing room and then never finish the new addition. At best, the solution is to change demo from the new phase to the previous phase. At worst, the phasing needs to be rewritten to have an intermediate phase between existing and new. A phase .5 between phase 0 and phase 1.
ADT267
Yes. Try showing a building with a previous extension being demolished. The rooms in the existing building are still existing but cant show them in the "new construction" phase.... unless we cobble together two different phase views on a sheet as @ambim said, or "copy" all the rooms into the new phase.
what about trying to set the phasing in "plan regions"?......   alas, no can do!!!
