Error CannotMoveTogether should give ID number
Pop out window when error CannotMoveTogether happens doesn't give suficient information to locate elements causing it. There should be ID number of componenet/s in the report.
(regarding error message: "Can't move these elements at the same time. One of them is restricted to moving in one direction while the other is restricted to moving in a conflicting direction.")
5 Comments
MiWolff
Doesn't "Export..." give you an html file that includes the id-numbers of the entities that won't budge? While far from convenient, it may help.
@MiWolff I just  exported html and I see the exact same info as in the pop out box. I'm using 2021 version, did it change it later versions?
MiWolff
@olga_lewandowska27W3Z Are you allowed to share your example file? If not, can you make an anonymous sample?
@MiWolff sure, how do I attach files here?
MiWolff
@olga_lewandowska27W3Z This being the ideas' comments, you may need to send them in a private message.
