Enumeration for Repeating Detail Layout values (API)
I was recently creating another Repeating Detail (RD)-related tool, and found myself wondering if there's an Enumeration in the API for the layout values for this parameter:
elementType.get_Parameter(BuiltInParameter.REPEATING_DETAIL_LAYOUT);
Google showed my previous post (finding and modifying Repeating Detail type), LOL, which gives the integer values:
// 1=Fixed Distance, 2=Fixed Number, 3=Maximum Spacing, 4=Fill Available Space
But I was hoping for something a little more robust/official. Searching the API gave: SpacingRuleLayout Enumeration
with the same names/values except for 4 (MinimumSpacing vs FillAvailableSpace), though that has a similar meaning in this context.
Member name Description
NoneNo points or lines will be created.
FixedDistancePoints or lines are separated by a fixed distance.
FixedNumberFixed number of points or lines with uniform distance between them.
MaximumSpacingPoints or lines are separated by at most the max distance.
MinimumSpacingPoints or lines are separated by at least the minimum distance.
Also, that Enumeration seems to be for a DividedPath, whatever that's used for, so I don't think using it over hard-coded integers would give me any real benefit (and would introduce an issue if that were to change).
